usocazy
- May 11, 2013
- 292
- 45
- San Antonio, Texas
- 2004
- Hemi 5.7l
I rewired an ABS module connector and would like to know the proper way to check my work with a multimeter.
Here's the connector that was replaced:
Here it is connected to the ABS module:
I had a ton of ABS code errors but have gotten them all cleared except the rear wheel speed sensor error and the brake & ABS light stay lit. I replaced the rear speed sensor, cleared the faults with my scanner and still got the same error with brake and ABS light still on.
Another forum member gave me the wiring diagram and I'd like to check the continuity on the rear wheel speed sensor wiring.
How would I use the multimeter to check this?
Thanks, in advance, for any advice.
