ABS Controol Module -C220049 intermittent failure .
JD2015
Jacksonville Fl
About a week ago my ABS lights came on, Pulled the code C2200049 ABS controol module internal electrical failure.
Facts :
Recently put new tires on rear move one of the rear tires to the front. 3 weeks prior to ABS failure .
Battery went bad - had it replaced , no change
I’ve done a break bleed and ABS bleed that did not change anything.
Interesting part is I’ve noticed if I drive the truck up to 50 MPH stop ,kill the engine and restart lights go away. Consistently and ABS and traction controol work normal.
Left to check/ do
-voltage at fuse panel
-alternator
-ground at abs harness
- remove clean inspect and reinstall
- yeah _ideas please
- where to get a replacement part
  • ABS Fail .pdf
J
JD2015
Jacksonville Fl
Update , still have not found a replacement co troop module . I removed the old one cleaned the contacts and reinstalled it. Now when I turn on the key only the traction controol light is on until ignition start the both come on.
J
JD2015
Jacksonville Fl
ITS FIXED!!! .. So I was able to source a salvage control module and on install the ABS light was out but traction controol was still on. Codes pulled for vin mis matched .Disclosure this will not work for everyone it depends on the programing mine did , the dealership rehashed the module and it works perfectly.
