HID Help please.
05singlecabHEMI
Lilburn,GA
i ran into a stumble on the HID kit. if anyone can help that would be awesome. i can video stream what i am doing live if that can help aswell. but here is my video. thanks!
YouTube - HID HELP
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
so i figured out the cords i did not know. they are the resistors. still a little iffy on the connections i have.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I have no sound at work but looks like everything is there just needs to be connected. I can try looking when I get home in a few to see whats going on in the vid. I deff saw the resistor and ballast and the bulbs looked like they were already in.
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
That would be awesome!
I took it out of my truck and decided to figure out how the wiring should go and then plug it up to the truuck
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Can you lay out everything on a table or ground and post a pic.. I can help ya I glanced at mine a min ago but its a diff kit.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Hey I got it give me a sec to explain it best.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
On my setup the resistors are looped with the light then straight into the ballasts. The 3 leads coming from that light are going to be plugged into your factory harness. Hope that helps.
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
on both sides does it go into the factory harness?
and so it is Lights->resistor->ballest?
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Yep you got the idea bud. My kit is older but had the factory plug on it where yours dont but has a similar wire setup.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
On the grounds run them under a bolt on the fender. The Ballests fit best on the cross support infront of the radiator. The relay is best put on the upper support on the drivers side. Far as the relays I have mine stuck over behind the lights on the fender support.
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
Yea that way didnt work... imma come back to it in a day or 2 cause im leaving out of town tomorrow. Damn. Really wish i knew wireing better...
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Dude, I've been off the forum this afternoon - should have popped me an email!
Gimme a few and I'll take a look at the vid. Also - if I am "busy", etc - Todd (who I resell HIDs from) always offers up service and support via phone as well. I'll pm you his number here in a few, but I think we can get you figured out bud!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
ok, let me take that pic you have and label it up! Gotcha here man.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
ok, try this Nick:
all bulbs come with those extra connectors on them - they are used on some vehicles, not in the Ram though.
Let me know if you have any issues - I'm on IM all night!
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
i have to get ready for my trip so i had to put it up :/ but i will try that when i get back this week end!
thanks Jeremy. i was actually gonna label a pic aswell but you beat me to it!
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
so was that set up correct?
and on the OEM connector i did not see anywhere where it could plug in.
there was a blue adapter that i thought the 3 stray wires off of the lights plugged in.
and the extra connector is the part that has the snap on?
i have the kit right next to me im gonna try and set it up again and ill take a pic.
thanks Jeremy!
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
ok this is the set up i got from the picture you put up.
that Blue part goes into where the old light was plugged into and the female wire near the relay, the short wire, im not to sure where that goes.
and for the blue adapter is that the wire set up?
thanks!
05singlecabHEMI
05singlecabHEMI
Lilburn,GA
okay made a new video that shows better then the picture. i like videos better cause can actually explain what i was thinking in my head...
Fatboy1989
