I'm looking for the location of the reverse bulb fuses. I hooked up some led flood lights for reversing. I hooked them into the wire harness feeding the left tail light. I found voltage on the white with brown tracer when in reverse. Floods came on for a few seconds and then out. Reverse bulb in the left tail light now dos not work. Right bulb works fine. I'm assuming there is a separate fuse for left and right sides. I didn't think the draw would be enough to blow a fuse. Is there another location to grab reverse voltage? I had thought about the trailer harness, but didn't know if revers was in there. My next idea is to just power a relay of the revers harness at the tail light. I have a constant 12v wire pulled to the rear that I can use for the main current to the floods. For now I just want to get the tail light working again.
Thanks
Thanks
