Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 4th Gen : 2009 - Present > Tech Info
Tech Info
P0481 code came up
This is a discussion on P0481 code came up within the Tech Info forums, part of the 4th Gen : 2009 - Present category!
First off I apologize if this is in the wrong spot, I am not sure where to put this My ...
Reply
Old 12-23-2016, 05:39 AM   #1 (permalink)
Ram Year: 2012
Engine: Hemi 5.7
Default P0481 code came up
My check engine light has come on. I got it read and it was a P0481 or "cooling fan control circuit." I have been reading up on it and it seems that the symptoms that my truck is displaying are backwards from what they normally would with this code.
When I drive my truck around it warms up quicker then normal. As I drive depending on how much gas I give it, my dash says my coolant is sitting around 190-210 degrees. Obviously the more gas the hotter it gets. However when I idle my truck from letting it sit, it will quickly rise in temperature to around 170-180 degrees but it will not keep rising until I start to drive.
If I am not mistaken shouldn't the truck be getting cooler as I drive it with the increased air flow especially if there is a problem with one of the fans? Also if there was in fact a problem with the fans shouldn't my truck be overheating instead of quickly heating up and then leveling out at what I assume to be normal operating temperatures?
If anyone has seen something like this and can give me some insight as to how I can resolve this problem I would greatly appreciate it. so far I have spun the fans with my hands to make sure that they weren't jammed and I have looked at the relays for any sort of nomenclature that resembles a fan. I.e. J19 60A RAD FAN and K11 RAD FAN LO RLY. J19 had the same fuse as the relay from the AC so I swapped them and the AC still worked which leads me to believe that the fuse was good for both of them.
Again, any insight would be appreciated.
Sponsored Ad
Register to remove this ad.
tuckerbj is offline   Reply With Quote
Old 12-23-2016, 09:29 AM   #2 (permalink)
Ram Year: 2014 Express Crew Cab
Engine: Hemi 5.7
Default
Just off the top of my head you could have a coolant hose that is collapsing under the greater suction that is created by heavier throttle and there is always the possibility the thermostat is bad. Those are two easy things to check.
__________________
ExpressRules is offline   Reply With Quote
Old 12-27-2016, 04:01 PM   #3 (permalink)
ramcares's Avatar
Ram Year: n/a
Engine: n/a
Default
Hi tuckerbj,
Sorry to hear about this! If you decide to visit your local dealership I'd be happy to follow up with them for you if needed. Just PM our page with your VIN and let me know!
Andrea
Ram Social Care Specialist
ramcares is online now   Reply With Quote
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Code P0481 Cooling Fan Relay 2 Control Circuit MikeMcG Engine & Performance 0 09-09-2016 04:25 PM
P1404 Code EGR Code bbd90 Engine & Performance 2 02-05-2014 12:31 AM
code help mr.breeze General Discussions 0 01-14-2014 05:42 AM
c code 23 jonathan greene Tech Info 2 02-25-2013 11:11 AM
2012 Ram Sport gauges go crazy and throws P0480/P0481 codes mrtosh Tech Info 6 07-11-2012 11:41 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
