Hammer_Z71
- Mar 20, 2011
- 248
- 6
- 2004
- Hemi 5.7
I have free access to a StarScan tool.
Background on what I'm trying to do:
I used to have my fogs ON with high beams via the short jumper wire from the high beam relay to the fog light relay. I've got a DIY out there on a couple of forums for this, works well BUT...
Fogs come on when you hit the high beams EVERY TIME. Used to not be an issue, I could care less if my fogs were on with them. BUT...
When I installed my 130 watt Off-Road lights, I wire the relay I installed to the fog light relay so I didn't have to mess up the dash with a switch (again not an issue unto itself because I hardly ever used the fogs and didn't care if they came on with the Off-Road lights, BUT...
I had to pull the jumper wire to the high beams, so as not to have my Off-Road lights on every time I hit the high beams.
The fix for this is to change the light settings on the PCM so fogs will stay on with the high beams. Thisaway if the fog switch is OFF, they will not come on, but if the fog switch is on, they will stay on with the high beams.
HERE IS THE PROBLEM:
I can only find the option for this on the TIPM (Totally Integrated Power Module) menu. I have an '04, therefor NO TIPM. It even comes back and says NO TIPM MODULE FOUND if I hit that menu on the StarScan Tool.
It was suggested that changing the PCM to CANADA zone operation from UNITED STATES would do the same thing but it only turns on DRL (Daytime Running Lights) feature. I've tried EVERY other country code (must be about 20 of them). Some make no difference, some turn on DRL and that's about the only difference I can find.
Am I missing something on the tool or do you HAVE to have a TIPM for this feature.
I'm about to pull the wire off the fog light relay and just run a damn switch to the dash, but figured I'd ask just in case there is a menu or option I am missing...
