a/c,heat ??????
Brian's07RamHEMI 4x4
Hurst,TEXAS!!!!!!
OK so my a/c an heat both blow but not at your feet,can this be diagnosted(sp) by me or do i need a scan tool to see why it doesnt blow out the floor??? When you select the floor it comes outta the defrost..whats the problem??? Thanks..Brian
SafetyGuy
Minot, ND
2008 Ram 1500 4X4
4.7L
no matter what selection it doesnt come out at feet? are any of the toher selections messed up? I believe the scan tool won't help unless you are throwing a CEL light. The heater controls are electrical so its probably a simple ground issue or short wire. Start at the floor selection are and work your way back making sure no wires are stripped or freyed. I bet when you look behind there you will find the culprit.
I havent actually taken it apart but try that I bet you find the reson.
SafetyGuy
Minot, ND
2008 Ram 1500 4X4
4.7L
the easiest way would be to get another "controller" from a wrecked dodge and try that one out. but if not like I said take it apart and if you have some electrical knowledge I think you would find it.
I am assuming alot on these post im sure someone that knows more will be along soon to help you out
adamwilkes14
sounds like a blend door malfunction to me too....are the ones on the Ram vacuum operated or electric? I am use to them being vacuum operated with the s10's.
shadow11
Banned
Houston TX
Its defiantly the blend door. Very common problem on the Rams
lilfroger
5.9 CTD
lilfroger
5.9 CTD
A BIG THANKS lilfroger,thats what i was hoping for!!!!!....THANKS AGAIN....Brian
I hope that works for you. I didn't do the install but know someone who just did it and he said it was a great install.
blackshadow
chesapeake va
sweeet that is good to know hopefully I won't have that problem with mine but you never know.
ChloeBrooks
