Death Shake
02RedRam
5.9 360ci
I have a 2002 Ram SLT 1500 Crew Cab. This truck started to have a nasty shake shortly after I bought it used. The shake starts around 60 mph and gets worse the faster you go. I do have a little mechanical know how.....it's not coming from the front, as there is no shake in the steering wheel. I have read about the rearend having backlash issues that could cause this...anyone dealt with this?
AWE Daniel
Banned
What have you had done to your truck? I have heard of this after people have leveled it.
ramhunter9
P-Star Jeep Wrangler
ya do you have a level ? also might be a bent rim or a ****** up tire .
02RedRam
5.9 360ci
Hasn't been leveled. I have brand new Toyo's on it, it has done it with two seperate set of rims, the old tires and new.
okarche_TA
Mine does the same thing. If u find a cure post it up.
ramhunter9
anything loose under there ?
ramhunter9
always the easy ones ... did you 2 get a good alignment ?
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
No steering shake 60 MPH in 2wd (I lived it for 2 years) = replace fromt 1/2 shafts, and she'll be smooth as butter. Dan
okarche_TA
I'm thinking carrier bearing. Are you.talking about the front drive shaft?
02RedRam
5.9 360ci
Replaced the passengers side shortly after I bought it.....grenaded on me....couldn't hurt to do the drivers too.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
CV Shaft, external to, and clipped to (the axle shaft) via hardy spicer pot via clip. Does that make any sense? If you where talkin to OP never mind "Miller Time"..
Goodie1990
