Mr. Baseball
Okay, I had a coolant leak, front passenger side. I thoroughly dried area one evening then started my truck the next day with mirrors and flashlight on hand. Truck started to leak at timing cover to block on passenger side. While apart I noticed timing chain/gears excessively worn.
With help of forum members, especially PCA4208, I was able to correctly replace timing chain and gears (I was only going to replace timing cover gasket). While apart I replaced water pump and thermostat (stuck half open) and water outlet.
While reassembling I rested my hand on front passenger side of intake manifold. To my dismay the bolt head was loose. I guess when at operating temperature coolant is leaking from there as well, I just didn't catch it. So after all the work to replace the blown timing cover gasket and related fixes I have to remove the intake manifold and somehow remedy this problem.
I really appreciate suggestions on best way to fix this. I have broken easy outs in the past, nightmare, so am asking for help. I know I have to replace the intake bolts, at least it says recommended with gasket set. Since 1 is already broken and rusted I will replace them. I hope no more break, 1/4 turn at a time (Haynes) and penetrating oil.
So anyone with any suggestions on removing and reinstalling intake manifold and/or best way to handle broken bolt I would really appreciate it as well as anyone else that has encountered this problem. Thank you.
