I just changed my brakes (rotors and pads.) while I was in there I noticed one of the calipers had excessive play on the slider pins so I changed it and also noticed a warn upper ball joint so that got changed out. Now I have a good case of death wobble. I took it to the shop and they went over the brakes to see if I messed something up. They couldn't find anything wrong with the brakes. They told me I may have broken a belt in one of the tires. So I rotated my tires and replaced my front shocks. Still wobbling in the steering wheel. So I took the brakes back apart and noticed the passenger side seemed to wobble when I spun it really fast so I took the rotors back to napa and exchanged both of them. Now it may be me being paranoid but now when I spin both rotors (all 5 lugs are holding the rotors tight ) they seem to sway back and forth. is it possible that both of my wheel Barings are bent. The Barings are about 3 years old. Before I did any work to the truck it had no issues it would track to the right but took a few hundred feet. Also the mechanic said the my left front tire seemed like it was wobbling when I picked the truck up and went past him.
