Hey gang, I've got a unique problem and a few questions.
I'm currently in Ouagadougou, Burkina Faso, thousands of miles away from any Dodge dealership. My friend has a 2000 Dodge Ram 3500 van from Canada, built in March of 2000, that was not getting spark. He took it to the local shop who's probably never seen an American V8 before, and they cut a lot of wires and spliced in new plugs to plug in an ignition coil, an alternator from something else, a distributor form something else, and a few other wires that probably didn't need to be messed with. That didn't work, so then they opened up the ECU and soldered around a bit trying to "fix" the problem. As you can imagine, opening up the ECU and fudging with the wires was not the answer. I can fix the other things that were messed with, but I'm afraid the ECU is useless now...but I'm not sure because all the electronics still seem to work, except we're not getting spark which is probably due to a bad ignition coil. The engine cranks, the headlights work, etc etc, but still no spark. Is there a way to test my ECU before I go ahead and order the proper other electrical bits that were messed with?? I'm afraid I'll order the proper parts, wait a month for them to get here, plug them all in only to find out that they ruined the ECU.
If I just assume the ECU is fried, and order a new one, can I just plug it in or will there be an immobilizer that needs to be reprogrammed? I called a Dodge dealership in the states and they said the new ECU would need to be programmed in the vehicle with a Chrysler computer....which Burkina Faso does not have. If anyone knows away around this, it's you wonderful people. So, is there a way around this?? Do used ECU's need to be reprogrammed too??
cheers and thanks in advance for any brain storming or info you can throw at me
