Recently noticed the high-beam indicator stays on even when the lights are turned off or on low beam when in use. My truck is a 98 5.2L Ram 1500 4x4 and here is the troubleshooting to this point.
1. Unplugged the wiring from the high-beam selector switch and hi-beam indicator stays on.
2. Verified operation of headlights
3. Unplugged one headlight at a time and high-beam indicator stays on.
4. Unplugged BOTH headlights and the high-beam indicator goes out.
5. Checked grounds located near headlights and didn't notice any broken or damaged wires. The connections were tight to the body.
6. Verified no fuse in the fuse box for the running light module. Installed a fuse but high-beam indicator does not go out.
