Chris828
Hey Everyone
First time posting. Just bought a 1999 1500 (SLT 5.2L 4x4 Manual). Not too long after buying it, I was driving down the highway at about 75 and my rear kicked hard. Engine was still running and it would rev when I hit the gas but there was no power going to my rear tires. I looked under it and the driveshaft had snapped off where it meets the rear diff. I looked a little closer and saw that the housing had cracked/burst (to the point that I could put a finger in it).
I'm not sure what failed in my rear diff but I have come to the conclusion that the easiest way for me to fix it is to get a new rear end from the junkyard. Id appreciate any tips/advice any of you guys have on getting the right part and replacing the rear.
The reason I am posting, is that when I was removing the broken driveshaft, I noticed a new looking SKU sticker on it. This has got me thinking that maybe this same issue recently happened to a previous owner (who fixed it and then sold it) and that I am going to replace the rear end and this will happen all over again.
Any thoughts on what might cause the problem? I thought the tires might have been oversized but I think they are the same height as stock (31.5") with 3.55" gears.
Thanks in advance, appreciate any insight you guys might have.
