Overload Springs
ramthis9501
Oklahoma
5.2 V8
Someone suggested that I should remove the overload springs and it'll give a little more drop. Are there any reasons why I shouldn't?
And I don't pull anything and hardly have anything in the bed ever.
txbass06
NE Texas
5.9 Magnum
That's the only reason you wouldn't want to lol. It'll lower the weight you can tow/haul and might make the rear ride a little stiffer
Trupiano
Registered User
6.7L CTD
You won't even notice the difference in the weight handling. It's just for if you "overload" your truck. I don't see that happening to anyone unless you haul a dinosaur or perhaps a elephant in the bed. I vote do it!
05singlecabHEMI
Lilburn,GA
I thought taking out a leaf would make the ride less stiff? Or is it cause its the overload leaf?
quietpeen
2021 TRX
Hellcat
go for it
bigbadram1500
Springfield, IL
I don't know much about lowering, but sounds like the overload springs are just for that, if you haul heavy stuff. I think you'd be ok removing them.
ramhunter9
P-Star Jeep Wrangler
I would not recommend doing it as you will experience a ride difference .
The overload spring not only serves as a "overload" but keeps spring tension .
Without it the truck will bounce on every bump ..
Ever seen a lowered style low rider going down the road ... how it bounces like crazy ?
Same thing
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Haven't done it yet lol
The rear rides really stiff though, you can feel every bump. I think if it bounces more then it'll ride a little better... plus the extra 1/2" or so drop would look good to :)
ramhunter9
You can always load the bed with sand bags to get .5 of a inch ..
Or just do it .. dont like it put them back in . Good luck buddy
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Comes to my next question... how do you get them out?
ramhunter9
If they have the belt clamp on them .... good luck
ramhunter9
Yours are not banded all together .. your good
05singlecabHEMI
Lilburn,GA
Isnt it just a bolt holding them together right through the middle and connected to the axle?
Why not just take a regular leaf out? That way you still have the overload and drops the same amount.
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Because the overload is the only one not connected at the front or back. All the others are. So would I have to drop the axle?
ramhunter9
The spring is a "spring pack " so NO , you can not break them . Only option is the overload
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Better question... what all would I have to do to remove the overload spring and then get it put back together?
Trupiano
Registered User
6.7L CTD
When I did mine, I took the entire spring pack and overload spring apart, then put them back together with a stronger bolt from the hardware store and the spring pack bands. Don't recommend doing it that way, cause it's a son of a B to put back together, and granted mine was a 3rd gen so it might be a little different... but it worked. :Grenade:
ramthis9501
ramthis9501
Oklahoma
5.2 V8
Could I just unbolt the belt clamp and slide the overload spring out?
ChloeBrooks
