Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Lifted
Sponsored Ads
Register to remove these ads.
Lifted
axle swap questions
This is a discussion on axle swap questions within the Lifted forums, part of the 2nd Gen : 1994 - 2002 category!
Register to remove these ads. It's free! So here's a lust of my questions. Mostly I want to have the ...
Reply
Old 01-07-2012, 08:31 PM   #1 (permalink)
Badger's Avatar
Ram Year: 1996
Engine: 5.9L Magnum 360
Default axle swap questions
So here's a lust of my questions. Mostly I want to have the 8 lug bolt pattern. This is because I can never afford new tires and there are always used wheel/tire Combos for 8 lug. I don't even know much about the dodge 3/4 ton axles. What's the gearing in them? Can I just bolt and go or do I have to do major mods? Any help is needed.
__________________
1. Debadged tailgate 2. Chrome wheel well trim 3. 285/75/16 Pro Comp All Terrain 4. Painted tail light covers 5. Tinted rear window 6. Factory style aluminum nerf bars. 7. Cobra CB with 4ft Barjan dual whips 8. Deer antler shifter 9. Rear coilover conversion 10. Stainless rocker trim 11. Shorty antenna 12. Custom light mount behind grille 13. Thrush Glasspack
Badger is offline   Reply With Quote
Old 01-07-2012, 08:44 PM   #2 (permalink)
Okiespaniel's Avatar
Ram Year: 2000
Engine: magnum, 5.9
Default
Gearing is either 3:55 or 4:10
The front is pretty much a bolt in IF you get the same year because later front axles had larger bushing bolt holes. Yes, you caould drill or replace the approopriate bushings, thought you should know. The holy grail of 8 lugs is a 2002 front...NO CAD!
Later axles have the more desirable dual piston calipers and ball joints. They also have a beefier 32 spline axle. Your brake lines will bolt up. I can't remember if the front shaft is a bolt up or if the differential joint is larger.
The rear is a bit tougher. Spring pads are outboard and to do it right should be cut off and re welded to bolt up to your springs. Again, newer axles have alrer brakes and your hose will bolt up. your rear drive shaft does have a smaller joint and is too long.
Lastly...front sway bar links vary.
__________________
Life is a Highway...I wanna drive it all night long...
Okiespaniel is offline   Reply With Quote
Old 01-07-2012, 08:51 PM   #3 (permalink)
Badger's Avatar
Ram Year: 1996
Default
That helps a bunch. Sway bars wont be going on if I do the swap anyways. I'm afraid the ram is shortly going to be retired off road only soon so from now on all mods will be geared towards that goal.
Obviously I can't just swap in new axle shafts that are 8 lug if its a different spline. Id really prefer to just that.
__________________
Old 01-07-2012, 08:55 PM   #4 (permalink)
Stangshcky12's Avatar
Ram Year: 2005
Engine: 5.9 Cummins
Default
Going to a 17" 5 lug wheel would probably a bit easier and cheaper
__________________
2005 Ram 2500 5.9 Cummins 6 speed
More Here
I blame spelling mistakes on my phone and I'm sticking to it!
Stangshcky12 is online now   Reply With Quote
Old 01-07-2012, 09:23 PM   #5 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
I believe he's looking for beef to slog through that dark black clay that is prevelant around the Mississippi valley. That stuff is sticky and either like mixed concrete or slipperly slurry.
Having recently purchased 17 inch rims for my truck I feel that tire selection is slim and used meats in runnable condition scarce as hen's teeth.
__________________
Old 01-07-2012, 09:31 PM   #6 (permalink)
05singlecabHEMI's Avatar
Ram Year: 2005
Engine: 5.7 HEMI
Send a message via Yahoo to 05singlecabHEMI
Default
well if you plan on doing an axle swap i have a DIY on it if you need help. ive taken out the axle on a 2nd gen about 6times now.
__________________
night vision HID kit, Pacesetter LT headers dual exhaust flow master 40series dumped before the axle, vararam air intake, 1.5inch leveling kit, Dakota AT^2 tires, plastidipped wheels. raceland 3" cutout, SC 3865 tuned, rocket wire, aeroforce gauge in a SRT 10 pillar with A/F ratio, color matched gill, plasti dipped bumpers.
05singlecabHEMI is offline   Reply With Quote
Old 01-07-2012, 09:37 PM   #7 (permalink)
Captain McGillycutty's Avatar
Ram Year: 2011 Power Wagon
Engine: Hemi 5.7
Default
Well I'm down to help for a 9.25 sas on a 1500 and then put a 11.5 aam axle in rear
__________________
2011 Dodge Power Wagon 5.7 Hemi Inferno Red/Black two tone - Lockpick, 12,500lbs Warn Winch, Bilstine Shocks, Lockers Fnt/Rear, Cb Radio, Wireless Warn Remote, Bushwackers, Super swamper M-16 40x14.5x20, 20" BMF Novekane Rims, Zone 2.5" level kit, HBS Steering Stabilizer, Custom Top Gun 8" lift kit
Captain McGillycutty is offline   Reply With Quote
Old 01-07-2012, 09:42 PM   #8 (permalink)
Badger's Avatar
Ram Year: 1996
Default
Yep. Unfortunately anything short of rockwells in the mud around here will break. But hopefully I can prolong it. Now I've just got to find me some axles. Now that I know what I'm looking for and what I need to do this should in theory be a cake walk.
__________________
Old 01-07-2012, 09:44 PM   #9 (permalink)
Badger's Avatar
Ram Year: 1996
Default
I do know that power wagon axles will bolt in though. 4 wheeler just did it.
__________________
Old 01-07-2012, 09:47 PM   #10 (permalink)
Ram Year: 2000
Engine: magnum, 5.9
Default
Does Reds Junk yard along the river in West Davenport still exist? It was called Big Reds at one time too.
I don't know if Big Red is alive yet buut his son John was pretty much in charge when I lived up there. They were total Mopar fanatics. Always had parts for my old junk.
__________________
Reply
Bookmarks
Tags
2nd gen axle upgrade, half ton axle swap
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frame and axle rust safetyfast General Discussion 6 10-17-2011 01:51 AM
Axle Swap Gebauer Lifted 17 10-16-2011 09:14 PM
1996 axle replace 05singlecabHEMI 2nd Gen DIY 9 09-09-2011 08:43 PM
Axle Seals RAM_007 Tech Info 13 04-05-2011 03:06 PM
should i go with a solid axle before i lift it? cr500 Lifted 23 01-22-2011 01:05 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
