figuring out a lift
LilRamMan
Haslet Texas
SmokedRam
Zephyrhills, Florida
These are the BEST way to lift your truck...they are lift knuckles. I say they are the best way to do so, because they do not change the geometry of your stock suspension components, but, they are a little pricey. If you do 3 inch lift knuckles, you will prob have to run a set of 1 inch blocks to level the rear with the front, unless you like riding with a little bit of "cali rake" (nose high)
94 95 96 97 98 99 Dodge Ram 1500 2wd 3in Lift Spindles | eBay
then of course, the least expensive way would be to get spacers. I believe in a different thread I explained to you how to figure what size spacers you would need. But, try to stay under 2.5 inches with the spacers. YOu will prob end up having to get 2 inch spacers or so.
Dodge Ram 1500 2" Front Leveling Kit 2WD 2006-2011 | eBay
LilRamMan
LilRamMan
Haslet Texas
Thanks so much man. Yes you had described spacers to me too. I was just wondering exactly what these things I found would do. I'll most likely just use the spacers, I was just curious to see what these lift blocks were. Thanks.
