is anyone running these?
Okiespaniel
Work, Shop, Computer
magnum, 5.9
You do know those are 8 bolt rims right? I'd go with something with a bit more backspacing to save your hub bearings. That'll be tough with 10's
E
eryk
5.9l 360
says this in the description "16 in. x 10 in., 8 x 6.50 in. Bolt Circle, 4.00 in. Backspace" i just assumed that meant 8 bolt, but what do you suggest for a slightly aggressive stance? to be honest i dont know to much about wheels and ive read a lot on the forum and google, but still only have a basic understanding
Stangshcky12
Oshkosh, WI
5.9 Cummins
They will fit your 2500 and they will stick out ALOT
I have wheels with 4.06" of BS and the fill my flares perfectly
They will stick out about 2" from the body
E
eryk
5.9l 360
wow thats an aggressive stance i like it a lot, what rims are you running?
Stangshcky12
Oshkosh, WI
5.9 Cummins
17x9 XD Strikes with a -24 offset/4.06 backspace with 315/70/17
They rub right now on the front with just a 2" level
I have a set of adjustable control arms I'm waiting for new bolts to come for and am probably going up another inch in the front and inch and a half in the rear
E
eryk
5.9l 360
I guess I didn't read anywhere that your truck is a 2500. :(
yeah i should have mentioned that i guess haha
sweet thanks for the info, i guess im gonna have to decide on how aggressive i want it to be
RYAN66
Denver, CO
5.9 cummins
I personally wouldnt run a steel wheel for anything other then offroad use, they are super hard to balance.
and as far as backspacing it all depends on what will clear and what stance you want, I went with -12 offset and it rubs pretty good at full lock on my 35's w/ stock suspension.
E
eryk
5.9l 360
is there any backspace on those or are they just -12 offset? and do you have any suggestions for wheels
Howells
Kitchener Ontario
5.9L
heres a really old pic of my truck, 15x10s, loved the wheels but found they rusted really fast and were super heavy, i know run 15x12s aluminum and there half the weight.
E
eryk
5.9l 360
wow those are sweet, but i think that might be to much of an offset for me because my state has that stupid "wheels cant stick out more than 2" law..
but im calling out the the ram community, what (black) rims do you think would look good on my truck(? theyre going to be wrapped in 35" tires
best picture of it is a video...
back woods hole shots - YouTube
Davy120
fairchild afb
Pro comp extreme 17x9 -6mm offset wrapped in 35s.
Sent from my MAN CAVE using Tapatalk 2
Davy120
fairchild afb
Another angle
Davy120
fairchild afb
Yep thems the ones
