05ram4x4
- Aug 28, 2012
- 597
- 34
- 2002 Ram 2500 4x4 Quad cab
- 5.9 Magnum
I have noticed that my bed is twisted as you might be able to see from the rear. I know my bed is rotted out underneith in the front passenger corner, so I figured it dropped in that corner. Looked closer and see that the bed is still lined up with the cab as far as body lines and the back window.
Now, looking at the pictures you might be able to see that the gap at the top between the cab and bed is smaller than the bottom..also, the body is in line down the side, but not in a straight line. It changes angle where the bed and cab meet. If that makes sense.
Has anyone come across this problem? Do you think my frame is bent on that side?
Sent from my SM-G950U using Tapatalk
