looking for aftermarket headlights.
'01 Ram
hey folks, i'm looking for pictures of aftermarket headlights that you personally may have on your vehicle or have seen around. i'm looking at some headlights now on ebay but am unsure of what they may look like on my truck. please post what you have. thanks.
suzukiquadrider
cummins 5.9, 6.6 duramax
Talk to JJ from retro shop he can hook you up with a sweet set of heads!
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
^would be his 1st 2nd gen truck to get them. I too want a set of retro fits
Here is mine
WhiteExpress
Midland, TX
I have run a wide variety on Gen II Rams.
Avoid the Ebay Projector headlights like the plague.
The 1 piece 'crystal clear' headlights have an acceptable beam pattern, but nothing great. I would reccomend finding a TYC Source *JJ* and getting the factory 98+ Sport Headlights. There is a bit of wiring involved to get the seperate High and Lows to work, but their beam pattern is the 'best" of the group.
Unless you want to get some HID Retrofit lights from JJ. I'd argue that to be your best bet.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
wow, them sport headlights are some expensive ********.
120 a pop, shipped! But I can get them on my TYC order if you'd like. :D
If you'd like for me to work some magic when they come in, I'm game too!
SilverHoghead
Born and raised in Hendersonville, TN. University
5.9 360 Magnum
the ebay one pieces do just fine.
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Heres what I run. I like them. Good light output. Clear lens, one piece. Not too bad. Got the blue imitation HID bulbs with them. I really like them.
And ya get them at the right angle they look blue.
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
If you go sport headlights, they make a wiring harness to do so. Saves alot of time with the wiring
SUL73NAZ
5.9L
I have some 1pc projector style lights of ebay... they are the exact same ones wermbang has but I baked them/ opened them up and painted the insides black. I also run HID's in the Hi's and Lo's. The beam pattern on the projectors is not bad but if you run the high beams everyone will hate you. I wired them to run the Hi's and Lo's at the same time.
Ramchowder
