My 2001 Ram on Xmas day is stuck in low gear, What is the issue, btw 240,000 miles filter changed once, I'm told shift solenoid replacement. thks. Joe in KS.
I would start with fluid and filter change, band adjustment, and replacing the solenoids. Cascade transmission parts sells a good solenoid kit. Would also delete the check valve in the cooler line.
If this doesn't help, you're probably looking at valvebody replacement at best but possibly the entire trans
