Ok good
Bring the motor up to opt temp (ya it sucks but this is a must do), label all the spark plug leads, drivers side is from front to back 1-3-5-7, pass side is 2-4-6-8, then remove them from the spark-plugs and put to the side. Next vac or blow out all the spark-plug holes, then remove the spark-plugs, then unplug the ignition coil 12 volt power cord at the coil, then remove the fuel pump relay found in the PDB, set the gas pedal to WOT, screw in the comp tester into #1 spark plug hole, turn the motor over three times, go and record your reading, move onto the next cyld and repeat for the rest of the cylds. Post back your results then we will see if a wet test is in order, if you feel like doing the wet test now add about a teaspoon of oil to each cyld then do the comp test as above. The wet test must be done after the dry test or the reading will be off.
Take your time and above all be safe.
