Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Engine & Performance
High idle, pretty stumped
This is a discussion on High idle, pretty stumped within the Engine & Performance forums, part of the 2nd Gen : 1994 - 2002 category!
So I narrowed my power surging down to a bad TPS. I put ran a graph in Torque Pro and ...
Like Tree1Likes
Sponsored By: Moe's Performance
Reply
Old 10-07-2017, 01:27 PM   #21 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
So I narrowed my power surging down to a bad TPS. I put ran a graph in Torque Pro and found this issue.
https://i.imgur.com/hmsIlby.png
https://i.imgur.com/4tCLSWE.png
Sponsored Ad
Register to remove this ad.
__________________
1996 Dodge Ram 1500 5.2L
Plenum Plate fix with Fel-pro gaskets
NGK V-Power plugs
MSD 8mm Wires
MSD Blaster Coil 8228
Accel Cap and Rotor
After Market Tow Mirrors (Don't care for the flip up but I'm happy they don't try to show me my own reflection)
Shadow_Death is offline   Reply With Quote
Old 10-07-2017, 03:08 PM   #22 (permalink)
Yeret's Avatar
Location: Under the hood, trying to find that ****ing bolt/nut/socket/wrench that I dropped...
Ram Year: 1999
Engine: 5.9 Magnum
Default
Got a break in the rain, so I went out to see what I could screw u...I mean, sort out.
Plugged in my scanner and went for a brief drive to see if I could catch the problem. I noted the TPS reading while sitting in Park and idling and went for a drive. Sure enough, the engine idled up so I shifted into park and noticed that the TPS was reading much higher than before. I gave the engine some throttle and noticed that the TPS was not responding right away so I revved the engine some. The TPS did eventually respond and the idle did settle back down, along with the TPS reading. Heading back and putting the truck in Park, I noticed that the TPS was not holding a steady reading like it should have.
Luckily, I still have my old TPS, which isn't bad (I only replaced it earlier this year as preventative maintenance) so I'm gonna swap it in and see what happens. If the issue is resolved, this will be the first time that I've had an issue with a Borg Warner part. And that's a little disturbing since half of the electronics that I've replaced are Borg Warner...
__________________
1999 Dodge Ram 1500 4x4 SLT Laramie
The only true screw-up is one that can't be reversed!
American Racing Nitro, K&N open element, modified 50mm, eBay shorties, 2.25" y-pipe, Magnaflow cat, Cherry Bomb Extreme, DUI LiveWires/cap/rotor, canned 91 tune by Flyin' Ryan, Hughes plenum repair, 4x4 Posi-Lok, on-board Money Sink 3000
Yeret is offline   Reply With Quote
Old 10-08-2017, 01:10 PM   #23 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Think I might be getting somewhere now. Swapped the old TPS in, ran the engine and it definitely reads smoother than the BW. Went for a drive, problem hasn't surfaced yet. Gonna drive for a few days and see what happens.
__________________
Old 10-08-2017, 02:33 PM   #24 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
Yep. I think I threw away my OEM Holley TPS by accident. I'm stuck with a Oriley's BWD part. I'll probably order a different part off Amazon and hope for the best tomorrow. I can say that Standard Motor Products is out of the question.
We distribute through traditional and non-traditional channels under our own brand names, such as Standard®, BWD®, TechSmart®, Intermotor®, Hayden®, ACI®, Four Seasons®, and through private labels.
I think I recall that this company also makes Duralast parts too.
Seems my only two options are Delphi and OEM. Mopar doesn't offer anything for a 96 anymore.
__________________
NGK V-Power plugs
MSD 8mm Wires
Accel Cap and Rotor
Old 10-11-2017, 05:21 PM   #25 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
Well, after a few days of driving, I can pretty safely say that a faulty replacement TPS was to blame for the idle problem. Haven't had any idle issues since I swapped the old one back on.
I do, however have a new little problem. It seems now that while cruising on the highway, if I hit a bump in the road, the engine briefly surges up about 200 RPM before returning to where it was. So, if I'm cruising 2,000 RPM and hit hit a bump, the RPM will jump to 2,200 RPM and then settle back to 2,000. Possible fault in my old TPS? I will say that the old TPS seems a little loose and if you tap on it, you can actually hear and feel something vibrating. Genuine OEM TPS is gonna set me back a hundred bucks though. Kind of a lot to spend on a guess but then, I'm pretty sure the TPS shouldn't "jingle" when you tap on it, LOL.
__________________
Old 10-13-2017, 12:39 AM   #26 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
I think it's safe to assume that it shouldn't rattle like that. I've also noticed that same thing with my truck when I hit a bump. I work right off I-35 and right before I get to my turn into work I have to drive over some "bumps" on the service road and every time the truck bumps a little the rpms go up like the TC is unlocking for a moment before locking back. Mine also does this going down the highway. I'm going to order a replacement this weekend if i can budget it in. If not then I'll just have to tough it out for another week. Mine also does this weird loping as it drives. This is what caused me to pull the sensor like I did. I was actually able to pin it to the loping of the truck. Loping/Engine surge.
Edit: I forgot that I found my old Holley TPS in the glove box.
Edit 2: Mine doesn't rattle so I suspect mine just has crispy electrical internals. Once it gets hot in the engine bay this thing just freaks out.
https://imgur.com/a/4obtU
They probably used the crappiest internals they could get their hands on.
__________________
NGK V-Power plugs
MSD 8mm Wires
Accel Cap and Rotor
Old 10-19-2017, 10:27 AM   #27 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
So a few days ago I threw my reader back on the truck with the old TPS made by Holley and saw this... https://imgur.com/a/vQY2f
So now I guess I'll be looking for a replacement that isn't crap.
__________________
NGK V-Power plugs
MSD 8mm Wires
Accel Cap and Rotor
Old 10-19-2017, 07:04 PM   #28 (permalink)
Yeret's Avatar
Ram Year: 1999
Engine: 5.9 Magnum
Default
I ordered an OEM TPS yesterday, should be here by Tuesday. We'll see if that does anything for me.
__________________
Old Yesterday, 08:31 AM   #29 (permalink)
Ram Year: 1996
Engine: 5.2L Magnum
Default
I found out that AutoZone uses Wells products now for their electronics. I cross-referenced the part number and it's literally a Wells TPS in a Duralast box. Went ahead and bought it. Instantly all my issues are gone except for that TC issue. So I did some digging and it seems there is a 5v wire in the transmission that handles the lock and unlock of the TC on these 46re. Some have reported it running through the insulation and shorting out on the side of the valve body and causing TC to unlock and lock back. I think if time and my budget allowes I'm going to drop the trans pan and change the filter this weekend. While I'm doing that I'll check on that wire.
Figured I would post these notes here. It does make sense as a short to ground wire as it only seems to happen when we hit bumps.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
High idle BrittRose Engine & Performance 1 12-12-2016 09:36 AM
High idle kit??? Freed127 Engine & Performance 0 04-01-2016 07:02 AM
high idle crazykid1994 Engine & Performance 6 09-30-2013 11:13 AM
high idle 5.9 ranney Engine & Performance 2 04-04-2012 05:18 PM
high idle 5.9 ranney Engine & Performance 1 04-02-2012 06:27 PM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
