11-24-2011, 03:20 PM
#12 (permalink)
Ram Year: 2002 QCSB 4X4
Engine: supercharged 5.9
i am using the eq heads. iron. 2.02's. i also sent mine to a shop and had them ported,valve job, and cc'd. the race shop was very impressed with them for a lower buck head. they were nice and true. no need for milling. i didnt want to up my compression because i was planning on a super at the time.(which i have now. just not installed yet)so i didnt want them milled anyway. i should have went with alum ones. they get rid of the heat better.alum are better for a boosted motor.
it all depends on what you are gonna do with your truck. mine is not a daily driver nor a tow vehicle. it took me months of research and thought before i started on mine.
i wouldnt do anymore than a 100shot on a stock bottom end.wish i would have went with a stroker now. but my motor only has 68k on it now and i could still see the cross hatches in my cylinder walls.
that is a nice kit that islacker linked to from hughes.
__________________
comp cam,2.02 heads,2600 stall,edel ceramic shorties,52mm fastman,sct,flexalite 180 e-fan,hs 1.7 rockers,k&n fipk,hughes airgap,aemwideband,aem boost,aem trans,msd coil,msd superconductors,msd streetfire ign,magnaflow,vortech s/c 8lbs,walboro 255pump,39lb inj.,intercooler. and a hemi durango murderd out.
