Oil PSI fluctuation
txbass06
NE Texas
5.9 Magnum
txbass06
txbass06
NE Texas
5.9 Magnum
That was my guess too. Just didn't want to start throwing parts at it if there was a common issue that caused it or not. Guess its cheap enough to swap it out and see lol
Okiespaniel
Work, Shop, Computer
magnum, 5.9
Unfortunatlly, there's no way to test the sender that I know of, and your symptoms don't suggest anything else like a no buss failure.
Usually a failing oil pump will have no pressure at idle.
You could hook up a mechanical guage if you have one lying around, buying one would be the same as a sending unit...:birgits_tiredcoffee
txbass06
txbass06
NE Texas
5.9 Magnum
Looks like it is the sending unit. Hooked up an old mechanical gauge to it after I got off work and it was reading a steady 42 psi at idle. I'll run by the parts house to get a replacement and swap it out tomorrow morning since I lost about 10 pounds in sweat this afternoon lol
Thanks for the help guys
Johnnguyen6596
