2000ramnky
I already have a vacuum leak that I can't find. A person with a hearing aid's weak battery could hear the vacuum leak (yes, I have wild vents, but have had no luck at all in fixing that issue.) But when the truck is cold from sitting overnight, it doesn't like to shift into 3rd. When I take off, it shifts fine into 2nd, but when it is time for 3rd, the engine just races. If I let off the gas, within five seconds it will shift, and going into 4th gear is normal. About the time it takes me to drive out of my neighborhood (less than two miles) it has started working fine. After it is warmed up, it also works fine. The only time it does this is when it is freshly cold.
Could this also be vacuum related?? The truck is the V6 auto.
