99RamSport360
- Oct 9, 2012
- 557
- 91
- 1999
- 5.9L Magnum 360
Truck "Half Cranks" but Won't Start and Fuel Pump Dead? Need Help Quick
So my truck has been dying lately after I start it if I don't keep my foot on the throttle. After driving for a while, it will run fine but then when I would go to start it again, it would just crank over until you tap the throttle and then the whole process starts all over again. Well that worked for a while and I was assuming the fuel pump was going out. Well now she's dead and won't even start. When I turn the key, it does what I would call a "Half Crank", and then it clicks and that's it. It won't turn completely over. I had someone turn the key to the ignition stage and listened next to the fuel tank to see if the pump came on, and of course it didn't so I know that the fuel pump is junk but that doesn't explain why my engine won't turn over anymore or does it? I'm now half convinced that the starter is now shot as well. Any help on this would be greatly appreciated because I move to college in four days and really need to get this fixed ASAP.
Thanks.
Thanks.
