Sub System Question
the codes
Houston, Tx
Magnum 5.2
Okay so I have a basic understanding of doing the wiring for my sub system using this guide.
How to Wire an Amp to a Sub and Head Unit: 12 steps - wikiHow
My question is, how can I wire a on and off switch to the system? I know at some times, when I have a head ache or just get tired of the bass I will wanna quite them down but I dont know how to wire that up..?
Any help?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
with my headunit I can turn mine off
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
toggle switch on the ACC line will do it too.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
or get an amp with a remote gain, turn knob all the way off when you dont want bass.
Most sub amps have this nowdays anyway.
TheMaddog
DFW
You should be able to turn your system on or off anytime from your head unit. If not, there should be a switch on your amp
quietpeen
2021 TRX
Hellcat
i 2nd getting an amp with a remote gain control.
TheMaddog
DFW
And plus, they're easy to install.
the codes
the codes
Houston, Tx
Magnum 5.2
^^yeah thats what I was looking for, can you put those on a different brand amp, or does it need to come with the amp to be compadable?
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
I have one of those sitting out in my garage somewhere, came with a lead wire to go to the amp. just would need to find it
the codes
the codes
Houston, Tx
Magnum 5.2
If you come across it let me know how much you want for it
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
just the shipping costs I will try tonight to look for it
the codes
the codes
Houston, Tx
Magnum 5.2
awesome, thanks. Just let me know whenever, not in a hurry.
Graygoose
Oklahoma
Convert, for now.
small
it's a basic phone wire jack is all it is.
HKkid
Missouri
I've got my remote wire only hooked up to a switch. That way I can turn it on/off as desired. In my last vehicle I had a switch in between the HU and AMP to do the same thing.
TheMaddog
DFW
To answer your question if you can put the kicker bass level to a different amp is a yes. I did it to mine. I have a Sony xplod amp.
the codes
the codes
Houston, Tx
Magnum 5.2
okay thanks, now im wondering if it would be easier to use the kicker level, or just run the remote wire to a switch haha
Graygoose
Oklahoma
Convert, for now.
small
the Kicker remote is plug and play, biggest time is running the cord from the amp to the gain knob on the dash.
Fryekenn
