magnum318
A week ago, my daughter put her car into the ditch. She called me to come pull her out. I thought that she was probably hung up and would need a little tug to get off whatever had her stuck.
When I got there I found her car sitting at about a 45 degree angle with one back tire off the ground. I figured that my pickup would be of little use but I hooked up the chain anyway and gave it a try. I was right. It took a 4x4 to drag the car back up on the road.
I currently have the factory LSD. Both back wheels were spinning but one was spinning about twice as fast as the other.
I've been considering a locking differential and this experience makes me wonder if I could have pulled the car out if I had one.
I've heard it said that a full locker in a 2wd will perform comparable to a stock 4x4. Is this true or is it just marketing hype?
Sent from my BlackBerry 9350 using Tapatalk
