Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > VP44 Pump
VP44 Pump
Winter is coming - Need a high idle kit?
This is a discussion on Winter is coming - Need a high idle kit? within the VP44 Pump forums, part of the Dodge Ram Cummins Diesel Forum category!
Reply
Old 08-23-2011, 04:20 PM   #1 (permalink)
Mopar1973Man's Avatar
Ram Year: 1996, 2002
Engine: 1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
Default Winter is coming - Need a high idle kit?
For those of you that live in the frozen north you'll want to consider building a high idle kit.
What Is It?
The Cummins ECM has high idle software already programmed in the ECM and Dodge disables it before sale. The high idle software will aid in warming up your truck in the bitter cold and reduces the risk of bending push rods and valve damage.
How do I get it?
There is 2 ways of getting the high idle software. One is using a Smarty programmer and the programmer will enable the software permanently for you even if you borrow a friends. Two... Is to go to a Dodge Dealer and get the flash done to enable it.
2nd Generation Dodge Cummins - TSB 18-019-01 - Cold Idle Engine Warming
So how does it work?
Well typically the flash will automatically start the high idle software and stop it under set temperatures. So 6 cylinder high idle is typically starts at 32*F IAT temp and 3 cylinder starts at 15*F IAT temp. But remember the grid heaters are running too so the temp outside has to be even colder.
So what the mod about?
Well my mod allows you to selectively select what mode of high idle when you want it. Summer day or cold winter morning without waiting for the conditions to be just right... Basically just 3 toggle switch and I'll explain how to use it.
Here is the wiring diagram...
The plugs can be purchased at Casper's Electronics.
CASPER'S ELECTRONICS - Quality Automotive Parts and Accessories - Specializing in automotive interconnect and wiring systems
Then the toggle switches and resistors can be bought at Radio Shack. (No lighted switch allowed!)
High Idle Fooler Operation
Cold Engine Start (Coolant <140F - Outside Temp > 32*F)
Turn on the IAT fooler and select normal high idle. Now start your engine. With in about 2 minutes the high idle should start. Once the high idle starts turn off the IAT fooler and allow the ECM to monitor the IAT temperatures. As the engine warms up to 170F it will cancel on its own and idle normally from that point on.
Cold Engine Start (Coolant <140F - Outside Temp < 32*F)
Turn on the IAT fooler and select 3 cylinder high idle. Now start your engine. With in about 2 minutes the high idle should start once it get to 1,200 PRM's the 3 cylinder mode with begin. Once the high idle starts turn off the IAT fooler and allow the ECM to monitor the IAT temperatures. As the engine warms up to 170F it will cancel on its own and idle normally from that point on.
Warm Engine Start (Coolant 140F-170F)
You can start the high software with a warm engine. At this point you need to use both the ECT fooler and IAT fooler. Select the proper high idle mode for your weather conditions as in cold start procedure. Once the high idle starts turn off the IAT & ECT foolers and allow the ECM to monitor both ECT & IAT temperatures. As the engine warms up to 170F it will cancel on its own and idle normally from that point on.
Forced High Idle
Turn on both ECT fooler and IAT fooler have it set for normal high idle. Start the engine and allow the high idle to start. Once the high idle starts turn off the IAT fooler but leave the ECT fooler on. This will allow a forced high idle that never ends. To cancel it just turn off the ECT fooler and it will cancel.
Video of Operation...
http://www.youtube.com/watch?v=il7iJCKfmaE
Prototype Video (Designing the High idle)
http://www.youtube.com/watch?v=P0Ah9nK3ahc
http://www.youtube.com/watch?v=umXz_xGxank
Sponsored Ad
Register to remove this ad.
__________________
2002 Dodge Ram 2500 (Cummins Diesel) -=- 1996 Dodge Ram 1500 (5.9L Magnum)
Mopar1973Man is offline   Reply With Quote
Old 08-23-2011, 04:24 PM   #2 (permalink)
ramhunter9's Avatar
Ram Year: 2012
Engine: P-Star Jeep Wrangler
Default
Great write up .
Question ? My PV2 has the high idle adjustment on it ... is it that simple ?
Here in Illinois we can see 0 degree temps nothing much lower but windchill sometimes is -10
My truck now idle's at 1k
ramhunter9 is offline   Reply With Quote
Old 08-23-2011, 04:25 PM   #3 (permalink)
Default
Originally Posted by ramhunter9 View Post
Great write up .
Still working the thread... Long... ANd your PV2 doesn't have 3 cylinder...
I think I got it all there for now...
__________________
Old 08-27-2011, 11:54 AM   #4 (permalink)
Default
I'm surprise there is no other comments to this... Wow! This is one of my popular mods... Even better yet no other Cummins engine can do it other than 98.5 to 2002... Ve, Ppump and CR can't do it...
__________________
Old 08-28-2011, 01:47 PM   #5 (permalink)
MarbleCrusher's Avatar
Ram Year: 2002
Engine: VP Cummins
Default
I knew the ve and Ppump couldnt do it but the CR cant either? For thr few days out of the year that I would need it in Texas I have the high idle feature enabled on my XZT+
-Jordan-
__________________
-02 Dodge 2500 cummins 4x4 6spd. Quad XZT+, Volant CAI, road armor w/ lonestar guard line-x'd, Fass 95 , 3in lvl kit, bilsteins.
-68 F-100, grandad bought it new gave it to me when i was 16 been restoring bak to factory ever since.
MarbleCrusher is offline   Reply With Quote
Old 08-28-2011, 02:04 PM   #6 (permalink)
Default
-Jordan-
Ummm... My winter temps might be well... Cold...
This years temp history McCall, ID
__________________
Old 08-28-2011, 02:14 PM   #7 (permalink)
Ram Year: 2002
Engine: VP Cummins
Default
Well the record for the lowest recorded temp ever in my area of Texas is -8deg ha ha ha
-Jordan-
__________________
Old 09-12-2011, 06:23 PM   #8 (permalink)
Default
Our morning are getting cooler. Right now we start the morning off at 50-55*F... By October the morning low will be 30-35*F...
Now the stock CR truck may or may not be able to set the cruise control and 6 cylinder high idle. But CR don't have any way of doing 3 cylinder.
Funny part is its firing every other cylinder which happens to be 4,5,6 and 1,2,3 is dead... Red is fired cylinder white are dead.
1 5 3 6 2 4
What really bad is if your pyrometer install in the 1,2,3 prot it won't move on 3 cylinder high idle. I've had people wig out over this one...
__________________
Old 12-04-2012, 10:22 AM   #9 (permalink)
oilfieldtrash83's Avatar
Ram Year: 2010 LB CC Diesel
Engine: 6.7 CTD
Default
I built my own mechanical high idle for my 01 cummins. Uses come custom brackets and a specific adjustable solenoid. Simple, non-intrusive, can never interfere with normal throttle operation, and a one wire hook up.
oilfieldtrash83 is offline   Reply With Quote
Old 12-04-2012, 07:20 PM   #10 (permalink)
Default
But remember that not safe.
The flash high idle is completely safe because it can cancel if...
Speed above 0 MPH
Coolant temp above 170*F
Brake Pedal Pressed
Transmission put in gear (auto)
Throttle pedal pressed
With yours the throttle remains high and could be dangerous... There is no way to self-cancel...
__________________
Reply
Tags
3 cylinder high idle, 6 cylinder high idle, high idle
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
idle clip. pavester Photos & Videos 10 02-21-2011 01:21 AM
Idle Videos Silverbullet08 Engine & Performance 40 12-13-2010 11:33 AM
Winter is coming..... jmoore General Discussions 20 09-01-2010 08:06 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
