Winter is coming - Need a high idle kit?
Discussion in 'VP44 Pump' started by Mopar1973Man, Aug 23, 2011.
  1. Mopar1973Man
    Mopar1973Man Senior Member
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    1996 Dodge 1500 (V8-5.9L) & 2002 Dodge Ram 2500 (5.9L Cummins)
    For those of you that live in the frozen north you'll want to consider building a high idle kit.
    What Is It?
    The Cummins ECM has high idle software already programmed in the ECM and Dodge disables it before sale. The high idle software will aid in warming up your truck in the bitter cold and reduces the risk of bending push rods and valve damage.
    How do I get it?
    There is 2 ways of getting the high idle software. One is using a Smarty programmer and the programmer will enable the software permanently for you even if you borrow a friends. Two... Is to go to a Dodge Dealer and get the flash done to enable it.
    2nd Generation Dodge Cummins - TSB 18-019-01 - Cold Idle Engine Warming
    So how does it work?
    Well typically the flash will automatically start the high idle software and stop it under set temperatures. So 6 cylinder high idle is typically starts at 32*F IAT temp and 3 cylinder starts at 15*F IAT temp. But remember the grid heaters are running too so the temp outside has to be even colder.
    So what the mod about?
    Well my mod allows you to selectively select what mode of high idle when you want it. Summer day or cold winter morning without waiting for the conditions to be just right... Basically just 3 toggle switch and I'll explain how to use it.
    Here is the wiring diagram...
    [​IMG]
    The plugs can be purchased at Casper's Electronics.
    CASPER'S ELECTRONICS - Quality Automotive Parts and Accessories - Specializing in automotive interconnect and wiring systems
    Then the toggle switches and resistors can be bought at Radio Shack. (No lighted switch allowed!)
    High Idle Fooler Operation
    Cold Engine Start (Coolant <140°F - Outside Temp > 32*F)
    Turn on the IAT fooler and select normal high idle. Now start your engine. With in about 2 minutes the high idle should start. Once the high idle starts turn off the IAT fooler and allow the ECM to monitor the IAT temperatures. As the engine warms up to 170°F it will cancel on its own and idle normally from that point on.
    Cold Engine Start (Coolant <140°F - Outside Temp < 32*F)
    Turn on the IAT fooler and select 3 cylinder high idle. Now start your engine. With in about 2 minutes the high idle should start once it get to 1,200 PRM's the 3 cylinder mode with begin. Once the high idle starts turn off the IAT fooler and allow the ECM to monitor the IAT temperatures. As the engine warms up to 170°F it will cancel on its own and idle normally from that point on.
    Warm Engine Start (Coolant 140°F-170°F)
    You can start the high software with a warm engine. At this point you need to use both the ECT fooler and IAT fooler. Select the proper high idle mode for your weather conditions as in cold start procedure. Once the high idle starts turn off the IAT & ECT foolers and allow the ECM to monitor both ECT & IAT temperatures. As the engine warms up to 170°F it will cancel on its own and idle normally from that point on.
    Forced High Idle
    Turn on both ECT fooler and IAT fooler have it set for normal high idle. Start the engine and allow the high idle to start. Once the high idle starts turn off the IAT fooler but leave the ECT fooler on. This will allow a forced high idle that never ends. To cancel it just turn off the ECT fooler and it will cancel.
    Video of Operation...
    http://www.youtube.com/watch?v=il7iJCKfmaE
    Prototype Video (Designing the High idle)
    http://www.youtube.com/watch?v=P0Ah9nK3ahc
    http://www.youtube.com/watch?v=umXz_xGxank
  2. ramhunter9
    ramhunter9 Supporting Member
    24,508
    886
    Jun 25, 2010
    Ram Year:
    Engine:
    P-Star Jeep Wrangler
    Great write up .
    Question ? My PV2 has the high idle adjustment on it ... is it that simple ?
    Here in Illinois we can see 0 degree temps nothing much lower but windchill sometimes is -10
    My truck now idle's at 1k
  3. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    Still working the thread... Long... ANd your PV2 doesn't have 3 cylinder... :Wedgie:
    I think I got it all there for now...
  4. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    I'm surprise there is no other comments to this... Wow! This is one of my popular mods... Even better yet no other Cummins engine can do it other than 98.5 to 2002... Ve, Ppump and CR can't do it...
  5. MarbleCrusher
    MarbleCrusher Member
    73
    Aug 22, 2011
    North Texas
    Ram Year:
    2002
    Engine:
    VP Cummins
    I knew the ve and Ppump couldnt do it but the CR cant either? For thr few days out of the year that I would need it in Texas I have the high idle feature enabled on my XZT+
    -Jordan-
  6. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    Ummm... My winter temps might be well... Cold...
    [​IMG]
    This years temp history McCall, ID
    [​IMG]
  7. MarbleCrusher
    73
    Aug 22, 2011
    North Texas
    Ram Year:
    2002
    Engine:
    VP Cummins
    Well the record for the lowest recorded temp ever in my area of Texas is -8deg ha ha ha
    -Jordan-
  8. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    Our morning are getting cooler. Right now we start the morning off at 50-55*F... By October the morning low will be 30-35*F...
    Now the stock CR truck may or may not be able to set the cruise control and 6 cylinder high idle. But CR don't have any way of doing 3 cylinder.
    Funny part is its firing every other cylinder which happens to be 4,5,6 and 1,2,3 is dead... Red is fired cylinder white are dead.
    1 5 3 6 2 4
    What really bad is if your pyrometer install in the 1,2,3 prot it won't move on 3 cylinder high idle. I've had people wig out over this one...
  9. oilfieldtrash83
    oilfieldtrash83 Member
    91
    May 26, 2012
    North central Montana
    Ram Year:
    2010 LB CC Diesel
    Engine:
    6.7 CTD
    I built my own mechanical high idle for my 01 cummins. Uses come custom brackets and a specific adjustable solenoid. Simple, non-intrusive, can never interfere with normal throttle operation, and a one wire hook up.
  10. Mopar1973Man
    47
    825
    Aug 22, 2011
    New Meadows, Idaho
    Ram Year:
    1996, 2002
    Engine:
    But remember that not safe.
    The flash high idle is completely safe because it can cancel if...
    Speed above 0 MPH
    Coolant temp above 170*F
    Brake Pedal Pressed
    Transmission put in gear (auto)
    Throttle pedal pressed
    With yours the throttle remains high and could be dangerous... There is no way to self-cancel...
Share This Page
