brake dust!?
night hawk
Rockport, Texas/ Wylie, Texas
what is the best way to get rid of that nasty build up of brake dust?!
it's been bothering me for weeks now!
i try to scrub it off, but there are still lots of black spots
HELP!
Born,raised and currently reside in eastern Ohio
1999 quad cab sport 4x4
5.9 Magnum=360CI
Have you tried Eagle1 A2Z All Wheel & Tire Cleaner?I just tried it with a wheel an brake dust brush(5$).And they dont seem to work bad together...Used it on my 95 K1500 suburban today(stock wheels)..Im trying to pretty it up to sell it...Since Im a Dodge ram addict now:)
night hawk
night hawk
well i went to o'reily and they had all purpose wheel cleaner i guess...
anyway, i tried it and it got most of the crud off, but there are still little black spots of it all over the wheels.
where did you get your stuff??
oggie
Mansfield PA
Scrap them with your finger are they soft ? (the black spots) If so it's tar you can use some cheap tire shine or wd-40 or tar remover.
5.9 Magnum=360CI
Good old walmart..Under 10$ for brush an the Eagle1 stuff..
5.9 Magnum=360CI
Just a update on the eagle1 stuff I recommended..As I said it worked great on my 95 K1500 suburban wheels yesterday.Today on my wife factory painted alum Oldsmobile mini van wheels ,it took some elbow grease...Just wanted to throw that out there..I dont wanna misinform anyone..I have yet to try it on my 99 Ram sport wheels
garner
Harker Heights, TX
does it get all of the little spots too?
and do you just use that or water and soap too?
Yeah it gets all the little spots on my wheels and when it doesn't then I just wipe them off with my finger or a microfiber towel. Then again my wheels are pretty new. You might wanna try some metal polish and see if that helps getting them off. I have some eagle one metal polish right now, you can pick it up at walmart for like $5(more expensive at autozone and all that)
Laramie1997
Springfield, Missouri
1997 Ram/2013 Charger R/T Super Trak Pak
5.2 (318ci)/5.7 (345)
Soft bristle toothbrush, chrome polish or aluminum polish with a microfiber towel and patience will remove that as long as it's not pitting...
huntram03
Cincinnati Oh
6.7L CUMMINS
MEAN GREEN.. yet again a walmart or Dollar Store product that works GREAT on anything! Before I switched to Ceramic brakes which work great, that is what I used on my factory rims and still use it on the Moto Metals..
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
may be best to pull each wheel off for a DEEP clean...
JJP71584
Pgh, PA
After all this, I would definitely switch to ceramic pads if you haven't already...
Needaram
SE WI
I just wipe mine with glass cleaner once a week
Deviate
St. Augustine, FL
2005 4x2
Once you get them cleaned like you want, use some Fukken on them. Then all you have to do is wipe them with a towel every once in a while and the dust just comes off.
night hawk
night hawk
is that the stuff that jj sells? ive seen pictures of results of it, and they look real nice!
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
yup! I sell some Fukken! :D
Gydian
I use Fukken to take brake dust off. Takes it out like it's nothin.
Silvertabb3
Cummins 5.9
i need to pick some of this up... stupid brake dust... im taking my breaks off ... who needs em... ?
