How hard is buffing out the paint?
Oefootball_70
OLATHE
I have a few scratches that people say (oh ****, that'll buff out). Well that doesn't mean a damn thing if you don't own or know how to buff.
Any pointers or links?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
gen a random orbit......unless you have a POS panel to play with first! Don't want to burn through your paint man.
Oefootball_70
Oefootball_70
OLATHE
Do companies do it? How much do they charge. I guarantee Ill screw up something.
shadow11
Banned
Houston TX
I have a possessional buffer and pads and if you don't know what you are doing you will mess it up. Its not just about buffing to get the scratches out you also have to wet sand to get the fine scratches out and then you buff it. This is the buffer i have
VvujQ6lUETvpRnXNk8GHd8HnrcN_qAwzZLZe4BcotLYQqqKjXfEBqYR-8X-qe1OZoiuBkFeHNlJ4EWhGHADrnjwDyeMg3D1VGpa9PsqIS7HurFlisNPreGl6h61kqIzNt-69me0ofaBNqg8OtzdVUa-aCPqQH2SHcXTE6N6p7sF8wiz0QFumnLhi
Oefootball_70
Oefootball_70
OLATHE
PER PANEL?? Scratches 1 - me wanting to make my truck look better 0
Oefootball_70
Oefootball_70
OLATHE
Were talking entire truck. Little stuff here and there. I want to make the paint look factory shiny again.
shadow11
Banned
Houston TX
At the body shop I work at we charge $500 for a complete wet sand and buff and the paint will look better than new after we finish.
The Assassin
B-more careful, Murderland
gotcha
Damn, that's cheap! I need my truck done.
pavester
texas
im in the same boat, i need my entire truck buffed. so many swirl marks and scratches. especially from when it was lifted :/
[email protected]
Horsham, PA
Cummins
First thing to do is prevent more scratches. Make sure you are washing the truck with the proper techniques. Use a 2 bucket wash setup with Grit Guards. Use quality soap (pH 7) and dry the truck with a leaf blower or Blaster Sidekick by Metrovac. Anytime you contact the paint, you are taking the risk of adding more swirls. Use a waffled microfiber towel to remove any final drips.
Watch the Junkman Videos:
YouTube - Junkman's 2-Bucket Wash Technique - Part 1
[email protected]
Horsham, PA
Cummins
Once you've washed the car properly, you will most likely need to claybar the paint. Use the baggie technique to determine if clay is necessary. Put your hand in a plastic bag, the thinner the better, and rub your hand across the paint. If the paint is not entirely smooth, you need to clay.
After clay, you will need to polish the swirls and scratches. I recommend the Porter Cable 7424XP. It is a very easy to use tool. Anyone can use it!
YouTube - How Safe is the PC 7424XP - Part 1
I recommend the Adam's line of polishes as they are really easy to use, they car color-coded to the pad, and deliver excellent results!
There are a bunch of kits Adam put together. I can add some FREE stuff to the kits for Ram Forum members.
Adam's Polishes
Email me to order or for help: [email protected]
ChloeBrooks
