Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > Dodge Ram Cummins Diesel Forum > 5.9 Common Rail
5.9 Common Rail
Running hot and no heat and whooshing noise
This is a discussion on Running hot and no heat and whooshing noise within the 5.9 Common Rail forums, part of the Dodge Ram Cummins Diesel Forum category!
Running hot and no heat and whooshing noise On my way to work this morning i did not have heat ...
Reply
Old 12-04-2015, 09:56 AM   #1 (permalink)
Ram Year: 2004
Engine: 5.9 Cummins
Default Running hot and no heat and whooshing noise
On my way to work this morning i did not have heat in my vehicle. Truck ran fine. On my way home I still do not have heat and I noticed a wooshing noise coming from the engine bay. The engine temperature was running slightly above 200 would creep up to about I would say 230 then back down to just above 200. Still no heat. This was all on the highway. 70 plus mile an hour speeds. Once I hit the surface streets the thermostat quickly rose the point where I felt the need to shut the engine off and let it cool. What's going on with my truck? 2004 Ram 2500 diesel automatic transmission.
Sponsored Ad
Register to remove this ad.
kjg26 is offline   Reply With Quote
Old 12-04-2015, 10:14 AM   #2 (permalink)
SilverStreak88's Avatar
Ram Year: 2007
Engine: 5.7 Eco Boost
Default
You need to see how much water is in the radiator, see if you see water running down the front of the motor or a puddle underneath when hot and cold. If you have no heat check to see if your passenger floor is wet. The wooshing noise is the water (what's left) in the cooling system getting pushed in (the word I can explain) like waves.
SilverStreak88 is online now   Reply With Quote
Old 12-04-2015, 11:23 AM   #3 (permalink)
Ram Year: 2004
Engine: 5.9 Cummins
Default
Sounded more like the engine fan wooshing...what kind of coolant do these trucks take?
Old 12-05-2015, 10:52 PM   #4 (permalink)
Ram Year: 2004
Engine: 5.9 Cummins
Default
Giant puddle of coolant under my truck. Pulled the radiator cap and found an empty radiator. Poured distilled water into the system and saw water flowing from under the water pump. Replace the water pump and went ahead and did the thermostat as well. I plan to flush the system entirely and refill with a 50/50 mix. Can you recommend proper flush method?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Running hot and no heat and whooshing noise kjg26 General Discussions 1 12-04-2015 01:49 AM
running boards making noise jakedetter Exterior 5 03-18-2014 05:02 PM
susupension noise / clunk + wheel bearing noise? sdamike General Discussions 7 02-26-2013 05:20 PM
Heat and Heat Vents Mega Mike Tech Info 11 01-08-2013 07:58 PM
No heat and running warm stimpson Tech Info 20 02-16-2011 09:35 AM
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
