ramcpu
- May 31, 2017
- 9
- 2
- 2014 CC
- HEMI 5.7
Has anyone installed the remote start kit (82214054) on a 2014 Express CC Ram that already had the connector taped back near the radiator and successfully used that connection for the hood latch sensor? I skipped using the kit's included hood latch harness because my truck already had the connector present. It was pretty corroded, but I cleaned it up with deoxit. I also tested the hood latch sensor and it gives different resistance values when closed and open, but no idea what the correct values are supposed to be.
I have everything installed and programmed by the dealer, but I'm getting "remote start canceled - hood open" when I try to use it.
The older version of the instructions dated 2/5/13 which I found linked on here says if the connector is present to use it, but on a second look the version that shipped with the kit is an updated version dated 7/28/15 and makes no mention of the pre-existing factory harness connection and only mentions to use the kit's included harness.
Before I go and install the additional harness, has anyone run into this with a 2014 and the remote start kit?
