AlphaCT
Need some help... What is the best way to run a CB antenna cable from under the hood (hood mount antenna) to inside the cab? Also, going to need to tighten screws under hood to go thru paint to contact metal on hood. What should I use to coat screws after to prevent rust? Thanks
