12sportmc
So do you have to hold the switch until the mirrors reach their final point or can you just press it once and watch them go?
Do they have a pre-set detent they stop at?
Have you ever had a problem of one mirror moving faster than the other and over-running the desired position?
I only ask as I'm about to pull the trigger on a set of these from 1AAuto and know with my '13 I'll be manually wiring the fold option. If I need to wire them to separate switches I can order them all at once. Thanks.
With mine wired to the rear window switch i do have to hold it until they fold and unfold. With a momentary DPDT switch you would just press it to the detent and the mirrors would fold. Either way is quick and easy. The motors cut power once they have reached the folded or unfolded position and I have never had any issues with them going faster than one another or going past the folded or unfolded positions. With them wired up like this you can actually fold or unfold them half way or all the way. Not sure why you would only wanna go half way but you could lol. Hope this answers your questions. Let me know if you have any more.
