Hey guys need a little help. Looked a couple different times and couldn't find any forums about this problem. I did a retrofit myself, and ran into a few problems I had to splice the wires in that connect to the ballast. The major problem I am having is when I turn on my brights the voltage drops on my low beams from 12volts to 3 volts. The ballast requires a constant 12 volts.
