How to mount lights behind the grill with no brackets
Thor09
Northern PA
Now that I took off my bullbar, I wanted to do something with my KC lights. They're 130W Stainless 6" Daylighters. I did not use any brackets. There may be other ways of doing this but this was the easiest way for me to mount my sized lights.
I measured across the metal support rail in front of the radiator and drilled holes to fit the 1/2" mounting bolt on the bottom of the KCs. I measured 6" on the drivers and 5-7/8" on the passenger side. The reason the measurements are different is I kept setting the lights where I thought they should be, put my grill back on, and measured from the center of the grill openings. I drilled about 1/2" in front of the metal rib running across the center like in the pictures.
Once drilled, I deburred and painted the bare metal with some black paint. Then mounted the lights using a large washer to hold the light in place. If you look in the pics, there is not alot of room to tighten the nuts underneath so you need to use an angled rachet wrench, not much else will fit under there. The passenger side is by far the hardest to tighten up.
Then I ran my wires to the lights and they worked! There is clearance between the radiator and the back of the lights and about 1/2" or more between the lenses and back of the grill. I'm going to keep an eye on them for a little while and make sure they are not rubbing anywhere else.
Thor09
Thor09
Northern PA
Continued...
EJM05
Somers, CT
440 Big Block
Awesome! I still need to mount my lights behind the grille. Awesome write up!
Thor09
Thor09
Northern PA
Thanks! It would have been alot quicker if I didn't make 2 trips to AutoZone....which meant re-bolting my grill back on each time, then off, then on, etc...I'm sure all lights are different but the only hard part was tightening those nuts, esp the pass side
EJM05
Somers, CT
440 Big Block
Where did you put your switch? Got any pics?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
very nice!
Thor09
Thor09
Northern PA
My switch is mounted under my dash underneath the steering wheel. I'll snap a pic for you tomorrow
EJM05
Somers, CT
440 Big Block
Awesome! Thanks!
LB3711
Trumbull, CT
3.6L V6
interesting. But inlike the 3rd gens that have a ton of room back there. Being that close to the grill your not worried about the lights melting the plastic? Halogens get hot and stay hot really close to the lens.
Thor09
Thor09
Northern PA
Melting and rubbing are my 2 main concerns so I'll keep an eye on them for a while to make sure.
WhiteExpress
Midland, TX
I wouldn't think it would melt anything. They would have to be up againts the plastic to even think about melting it.
How close are the lights to your Grille? lol
Yea... I melted the factory honey comb on my '99 Ram with 100W lights that where about 1/4" away. Just saying.
I think they look great! I'm considering a very similar placement
Thor09
Thor09
Northern PA
More pics in daylight and the front and rear clearance between the radiator and the grill.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
man, now you got me thinking about doing this.
Thor09
Thor09
Northern PA
I just made it up as I went along, feel free to improve my idea!!
swamp_life hemi 05
Tallahassee Fl.
2005 laramie
That looks pretty awesome! I was goin to do this till I bought the light bar from loadedlaramie, now just to get some lights..... Why do they have to be so expensive!
Droid Incredible 2 on the move!!!
Grubrunner
Sorry to drag an old thread but I'm interested in any updates.
How have the lights held up.... andy melting of the grille after prolonged use.... any rubbing issues that have surface.... anything else?
I'm about to undertake a similar task [different lights, same mounting method] and was interested in anything further you may have to add.
Thanks.
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
Nice, that would be something that I wouldn't mind doing myself.
phorrestphire
