INFO - 2013-2018 8.4A /AN FW Notes (RA3/VP3-NA & RA4/VP4-NA & UAx)
R.L.K.
Bristol , Tn.
to ami the same happened to me I do not have navigation when I did the update you know what is the link on eBay for the update
Enviado desde mi iPhone utilizando Tapatalk
Adum12
Wisconsin
I am in the process of putting a 8.4 VP4 NA part# 68258671AG software version 15.41.4 in my 2015 1500. The truck came equipped with the smaller touch screen model.
However I have run into a snag. I don't get any volume and on the settings page I cannot access any of options I get a message saying key must be in run position. I am at a loss I don't know where to go from here.
Please can someone help me.
SitKneelBend
St. Louis
3.6 Pentastar
Can you send a picture?
SitKneelBend
St. Louis
3.6 Pentastar
What would you like a picture of?
"on the settings page I cannot access any of options I get a message saying key must be in run position."
SitKneelBend
St. Louis
3.6 Pentastar
That's strange...is the radio from a RAM truck? If you can I would try to perform s factory reset on the radio. Hold down the hot and cold HVAC buttons until a menu pops up. Hopefully you have the 8.4 HVAC control bezel already right? If so, there will be a factory reset option in that menu.
Adum12
Wisconsin
Yes it is from a Ram. I got it used. Came with the bezel wiring and additional module . I did the factory reset . Only thing that changed is now the background shows the u connect logo and not the silver brushed background. The only way that it will make sound is if connected to my phones Bluetooth and I make a call . It will play through the truck speakers .
SitKneelBend
St. Louis
3.6 Pentastar
Yes it is from a Ram. I got it used. Came with the bezel wiring and additional module . I did the factory reset . Only thing that changed is now the background shows the u connect logo and not the silver brushed background. The only way that it will make sound is if connected to my phone and I make a call .it will play through the truck speakers .
Do several power cycles. Key out, door open then close, wait for dash lights to go out then turn the truck back on. Let radio power up completely and repeat (x3)...
Mpgrimm2
Mpgrimm2
SC
2022 Ram 1500 (5th Gen)
5.7L
Take a look at post 5 about possible issues with 2016 Ra4 Radios in earlier trucks.
https://www.ramforum.com/index.php?posts/1125807
This sounds like your issue. Read the 2 linked posts there and let us know if you think it's the same?
I tried 3 2016 radios in my 13 ram and couldn't get any to work. Tried updating the FW in my truck and partially brick it. If it's not recognizing truck is in run position, don't try the update. Worked fine in DeereGuy's 16 ram 2500.
PS: where did you get the conversion harness? Are the wires all the same color (ie white = GuK or Green = Bck57)
M² Mods.
Adum12
Wisconsin
Yes ( No Sound/No Volume up & dwn control. "Settings"menu locked out/doesn't recognize key in "run") is exactly what I have going on . I bought the kit form a guy on Facebook 4th gen page he had it in a 2015 as well. The harness is all white wires.
Mpgrimm2
Mpgrimm2
SC
5.7L
Just curious... Got a picture of the harness before you installed it?
Sounds like a 16 radio is a no go in your particular truck. Can you return it?
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
I bought it from a private party.
Not just because I make them but, Ugh....
Are those 3m Scotch Lock splices on there? That looks rough & like a problem waiting to happen/fail. Can't imagine what the crimps inside the connector look like if the splices for the bezel aren't even soldered. That's just bad.
M² Mods.
Adum12
Wisconsin
First thing I did was cut out the sections of damaged wire from the Scotch locks. And replace with heat shrink barrels . I am an electrician by trade so I know those things are bad news. (Since all the wires are white I did this one wire at a time so there was no confusion .)
Mpgrimm2
Mpgrimm2
SC
5.7L
Is there a part # for a radio that you can recommend .
All the ones from the OP are usually trouble free, except the 2016 radios. FW version 17.43.x is the latest (17.11.x allowed backup and cargo cam at same time). 2017 Ra4 will have the newest map files.
Here's one for $600 (a bit high but not by much)...
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/263977682615
Note: the first 3 digits of the PN are unique for each model year. Last 2 alpha digits don't matter.
If you can find a decent deal on one you can even install a 2018 UAx radio (Android Auto/CarPlay), but yours need a 2018 HVAC module, 18 USB hub, & hub adapter harness....
M² Mods.
Mpgrimm2
Mpgrimm2
SC
5.7L
PS: not sure if you have to have nav but etTodd has a good deal on a 2015 RA3 ...
bump. 250.00 shipped
https://www.ramforum.com/index.php?posts/1833633
PS: just to add, that 16 Ra4 probably doesn't have anything wrong with it, just that your truck's BCM doesn't like it. If you know anyone with a 13-18 ram near you that can test it in their truck, you could verify it (16 or newer would be best).
M² Mods.
SitKneelBend
St. Louis
3.6 Pentastar
If you come down near St Louis for any reason I'd test it for you. I have one you could test for me too (not sure if the NAV works at all or just doesn't work in my truck).
Mpgrimm2
Mpgrimm2
SC
5.7L
Hi everybody, was wondering if anybody has the 2014 RA4 8.4” vp4-ca radio Uconnect software on a USB stick that their not using? I cannot seem to find a way to download a copy, as I don’t have the original vin, hopefully someone can help me, it would be greatly appreciated
-Barry
Just relisting this here to see if anyone can help Barry out.
M² Mods.
