Are you using copper or iridium plugs? I had a problem with #3 in mine, I had swapped to iridium when I had problems with mine. Even bought the higher end ngk plugs. After replacement, had same misfire. So I went back to buy the OEM copper replacements, smooth sailing after that. Idk if that was specifically what caused it, but I'm guessing dodge put those is specifically for that model yr for a reason. I made sure the replacements were gapped properly. That could be another problem you're having
