Emergency Brake Flashing
docdog21
I just bought a 2003 2500 with 5.7 hemi. Ive had it for a few weeks and havent used the E-brake yet last night though out of no where while driving the truck the e-brake light started flashing on and of also a couple minutes later the heater completely shut off. The heater came back on after shuting the truck off and then restarting it but the e-brake light is still flashing. I dont know much about working on cars but im trying to learn. I feel like since both of these things happened close together and out of nowhere it has to be some electrical short. Any suggestions as to what it could be or how to fix the problem would be greatly appreciated.
Thank You
Trenton
did your foot hit the pedal? try applying it fully then releasing it again
D
docdog21
Tried that didn't do anything.
justin13703
MD
Check the brake fluid, some vehicles will light the brake light if the fluid is low.
buckeyexx
Ohio
2016 Power Wagon
Ever figure out the issue?
JonTownsley
Magnum 4.7
Mine has a similar issue right now and it's connected to the abs system. Rear speed sensor (top of rear diff) is faulty. Does your speedo work during low speeds?
pajeepman
SE PA
5.9 magnum
Every now and then when i put my '03 1500 5.9 in park, the abs and parking light warning lights come on and flash a ding for a few seconds, then it goes off. No idea why, everything else works ok
Sent from my SM-J320P using Tapatalk
JPT
NY
2015 Big Horn
Brake fluid at the right level? (Not low)
