rocket
Licensed Dynacologist
- Jun 26, 2010
- 18,075
- 3,919
- connecticut
- was 2006
- was a HEMI 5.7
This usually gets overlooked and I apologize for lack of pix. But it really is quite simple.
1) open hood
2)located on the inner sides of the lamp(s), are 2 bolts with body clips. 10 mm.
lefty loosey, righty tighty...
3) inside of the front wheel well(s), you will find a rubber grommet....pull that and you will see a 10 mm nut.......take that off
4) Now the headlamp is actually secured by a ball pin housing, to release, I use a flat bladed chisel wrapped in a towel, and I put this in between the head lamp and fender panel.
With the other hand I pull on the headlamp where the front bolts were and gently pry apart with the towel wrapped chisel.
5) Apply electro gel too all bulbs being replaced and'' never seize'' on all bolts and nuts when reinstalling lamps.
1) open hood
