05singlecabHEMI
i spent today replacing the axle on a 1996 5.9 ram 1500. we got a rearend out from a 1996 ram 1500 in a junk yard. i believe it is the 9.25 rearend. this truck did have gear put in by the dealership to which i believe are 3:92. this is the truck that snapped the axle clean off in another thread i had.
Also, i didnt think about doing a DIY on this at the time so i sorta reacreated the old rear end in the pictures. some years may be different.
1:jack the truck up. we found the best way was to jack it from the differential itself and get both tires off of the truck because of the LSD and then lowered it onto safty jacks on the frame, still both wheels off the ground
2: take the wheel off and also the drum brake cover.
3: take the differential cover off and let the fluid out into a pan. and should see this. *in this picture there are 3 other small gears that you will see when open the diff. this is the junk one so we took the gears out*
the peice touching the pin is the axle you will be replacing.
4: now you need to locate the bolt that keeps that pin in. you may need to spin the wheel to get it in the right position. to get it out. now the junk rearend was a 8mm 6sided bolt. but the one in the truck was a 12sided 8mm
5:remove the bolt. to get the pin out, we found the better way was to push it a little then turn the wheel again so you can pull it toward you. but DO NOT pull the pin all the way out. otherwise the gear will come off and will take all the other small gears with it. just pull it to wear you can keep the gear on it. without pulling it all the way out.
6:next you need to push the axle in a little and there is a C clamp you need to remove.
7: now the axle is free and all you have to do is pull it out. once it breaks free of the differential though itll get caught. All you have to do is push down on the axle to get the whole bar straight and you can pull out. and your axle is out!
sorry there wasnt much pictures. like i said i wasnt planning on doing a DIY untill it was done. also i am not responsible for any damages or injury during this process. this is the way we did it, and can be different for every year and ever person.
if you have any questions ill try to answer them the best i can.
