Go Back   DODGE RAM FORUM - Dodge Truck Forums > Dodge Ram Generations Forum > 2nd Gen : 1994 - 2002 > Tech Info > 2nd Gen DIY
Sponsored Ads
Register to remove these ads.
2nd Gen DIY
Gurgling behind the dash DIY
This is a discussion on Gurgling behind the dash DIY within the 2nd Gen DIY forums, part of the Tech Info category!
Register to remove these ads. It's free! Ok so a question has been asked about gurgling sounds fromt he dash. ...
Reply
Old 08-07-2011, 09:10 PM   #1 (permalink)
Bigtman07's Avatar
Ram Year: 1998
Engine: Magnum 5.9
Send a message via Yahoo to Bigtman07
Default Gurgling behind the dash DIY
Ok so a question has been asked about gurgling sounds fromt he dash. This normally means that there is air in the coolant system. But have no fear here is a simple DIY to help ya burp and top off the system.
Step 1: Pop the hood and check your overflow tank
Step 2: If the tank is low add some more coolant to it.
Step 3: With the truck cold open the Radiator cap and check the fluid level. If need be add half and half coolant to the radiator till full.
Step 4: After radiator is full and the truck still cold leave the radiator cap off and start the truck. Then let the engine warm up till the thermostat opens. Here the coolant level will rise a little then fall.
Step 5: As the coolant level falls add some coolant till full while the truck is running. This will help burp the system of air. Apply a small amount of throttle while burping. Fill to the lip them add throttle the level will go down. Let off the throttle and if the fluid doesn't riase add more. Do this till the throttle causes the fluid to rise and fall about the same amount.
Step 6: After a steady level of coolant is in the radiator put the cap back on the radiator. Now fill the coolant bottle to the warm full line. You should now have toasty heat and a cool engine.
Enjoy.
__________________
Never Apologize for being Patriotic! 'EM
"If he's gonna put his lips on something I made I'd rather it be a duck call." ~Willie Robertson
New Here? Introduce yourself here - Click here to become a Supporting Member - Check out our Preferred Vendors!
Bigtman07 is online now   Reply With Quote
Old 11-10-2011, 09:19 PM   #2 (permalink)
YoMoma's Avatar
Ram Year: 2001
Engine: 5.9
Default
Thanks for the tip. This last spring I topped off my radiator. I noticed this gurgling sound for a month or two after topping off the radiator. Thought it had to do with me squeezing the radiator hose after filling. Seems to have went away since then. I figured it had something to do with when I added antifreeze. Only heard it for a couple of blocks after starting the truck. Went away after that.
__________________
I Have Yet To Begin To Procrastinate!
YoMoma is offline   Reply With Quote
Reply
Bookmarks
Tags
better heat, burp coolant, cooling engine, diy coolant, dodge ram coolant, fill coolant system, gurgling sound
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
2nd Gen LED Dash DIY Bigtman07 2nd Gen DIY 13 03-07-2012 02:32 PM
Dash lights wermbang Interior 22 04-08-2011 07:48 AM
looking for after market dash chris b Interior 5 04-01-2011 11:51 PM
dear dash.... kajunboy89 Interior 10 01-30-2011 03:29 PM
dash leds srt2slow Interior 11 12-13-2010 03:17 PM
Fully Driven Auto Network
GM Truck Forum
Ford Raptor Forum
Chevy Tahoe Forum
Chevy Cobalt Forum
Chevy Camaro Forum
Toyota FJ Cruiser Forum
Ford Truck Forum
88-98 GM Truck Forum
73-87 Gm Truck Forum
Ford Expedition Forum
Chevy Equinox Forum
Chevy Cruze Forum
Jeep Liberty Forum
Jeep Forum
Dodge Ram SRT10 Forum
Chrysler 200 Forum
Scion xD Forum
Scion xB Forum
Dodge Challenger Forum
SRT Forum
Nissan Titan Forum
Buick Enclave Forum
Cadillac Forum
Cadillac XTS Forum
