Upper Dash Panel Replaced!
brewman
Suwanee, GA
2019 Ram 1500 Laramie
5.7L Hemi w/ eTorque
I recently completed the replacement of the upper dash on my truck and I wanted to share a few photos.
While I've read about people replacing the upper dash panel without completely pulling the dash from the truck I don't see how that's really possible and certainly would be much more difficult. It took me a couple hours to pull the dash since this was the first time I've done it, but I feel I could do it in under an hour now. I've got lots more pics, but for the most part it's a pretty straight forward process. I followed the steps in the factory service manual. and it was tedious but certainly doable.
Here's a link to the relevant pages from the 1997 factory service manual
Here's the dash prior to removal. I had already pulled the bezel and disconnected from the cowl.
All gone
I fixed some of the broken plastic support structure with 1/2x1/8 aluminum strip epoxied in place to add strength
Attach the side molding and side defrost vent tubes to the dash panel before attaching the dash panel to the dash (do both sides).
Using a dremel tool I had to widen the slots on some of the duct connetors in order to get them to attach to the dash defrost vents without having to put pressure on the dash panel to make it fit. I would not be surprised to find that many dashes from the factory crack because the plasic panel is stressed to make it fit the ducting.
Don't forget to transfer your VIN from the old dash
Here's the finished product
adamwilkes14
Nice write up!!! I need to replace mine too, although it isnt as bad as I suspected as I have now had a chance to see other second gen dashes, LOL...I am just gonna opt for a glued on cover for mine.
txbass06
NE Texas
5.9 Magnum
Nice info. Mine has one small crack in it, but it still drives me crazy. I'll just replace it if I have to replace the heater core
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Good writeup!!! We needed something like this! Thanks for sharing!
B
brewman
Suwanee, GA
Very good job! Surprised you didn't go ahead and replace the heater core at the same time.
I had thought about replacing both the heater core and evaporator, but I'm not having any problems with either one so I let them be. After doing the dash replacment I think I can pull it again in about an hour, and there's enough stories about leaky replacement heater cores out there that I decided to wait until it's necessary.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Very good write up and welcome to the site bud.
Mopar1973Man
New Meadows, Idaho
By chance could you tell me where you got your new dash at?
fonzyn75
Looks good! I gotta do this to my 2000 LOL
kawiultra99
360 CID
Great job! What was the toughest part of the job? I need to do mine.
tfink
Great Job! Getting ready to do the same thing. Picture are very helpful. Did you have to remove the steering wheel. I couldn't tell from the pics. Also, any service manual (pdf)?
WhiteExpress
Midland, TX
You can just lower the steering wheel out of the way.
However, if you're in there, you can buy a delrin(?) bushing to go in the column and clean up some of your slop. I'll be damned if I remember where I bought mine from, but it helped a lot in my '00 Ram.
tfink
Glad to hear the wheel does not need to be disassembled. RE delring bushing - steering wheel operated smooth and quiet (Knock on wood), but will keep that in mind while the dash is out. Any other suggestions of things to replace while dash is off. Thinking about cleaning out vent system.
RamPart3.9
Georgia
Love your pictorial progress depiction of the project and your explanation! Great job and looks great!
MagSport
South Carolina
Lmc and ebay offer them, I just replaced mine with a lmc kit. Super hard to install with the windshield in but it makes such a difference on looks and cabin noise.
Fryekenn
