Are all Oil filters the same ?Are you just paying for a name or brand?
WhiteExpress
Midland, TX
I run the Mobil 1 filters, after reading Bob the Oil Guy and other cut open comparisons.
Joshwaa
Lake Worth, FL
2016 CC 4x4 Laramie AirRide
I support Mobil 1 filters all the way. I have almost 100k and my oil still come out pretty clear.
AJMAG
new jersey
Mopar or Fram extended guard for me
some people say if you cut any filter open its the same thing.. but i dont trust that. like Zack said, expensive truck might as well spend and extra couple bucks and ease your mind
Red 2012 Crew
Central Illinois
As long as you change your filter regularly it won't make any differance in a pickup truck. I run a fleet of tractors and have a couple of big trucks so I have researched this topic alot. A pickup only uses 75% of its power maybe 10% of the time, (if that makes any sense). It doesn't need the protection that a tractor that uses 90-95% of its power 75% of the time and in dirtier conditions all the time than most of our trucks ever see. Just make sure you change your oil and filter every 3000 miles with conventional oil and 5000-10000 with synthetic and you will be just fine.
03MopaRamman
RAM SPORT / 18 SRT
Southern Alberta
Good one I Like That and very True for me as only 10% of the Time do i have the gas pedal 3/4 of the way down to the floor...LOL...Joke
But seriously I don't want a cheap oil filter on my old truck as I am using a 6.1 oil pump and often will hit 6400 RPM while shifting the B&M.
Bigdaddyii
I either use Mobil 1 in both trucks or Mopar for my Ram and Motorcraft for my F150. I don't guess it would matter much what I run on there as I dump the oil (Mobil 1 as well) every 5k anyhow.
USMC1188
SW Ohio
None
Truckless...
Amsoil Oil and Filter
I used to use Mobil 1 Filter and Royal Purple Oil and had great luck as well
scott2488
Olney, IL
Not all oil filters are made the same. I worked for a Company that made oil filters and we used steel end caps in the filters. there are companies that use paper end caps in their filters. Just like the commercial says.
I also know that the company that i worked for bought out Fram filters and i would not hesitate to use the filters.
S
scotts2012ram
Guest
I use mopar filters I see it as it one less thing they can try to blame. I don't really like them to me there made of thin metal on my first oil change. I bent the hole filter like a coke can getting it off its time for the 2nd will see how it does. I've tired frams on my other trucks I loss pressure every time its only 2-5 psi but I just don't like that.
Goodie1990
