Ford F150 question....
KansasArt
Kansas
2002, 4.6L 150,000 miles. Was my old pos truck before getting the ram. I sold it to my daughter's bf for only $500. He's a full time student and doesn't have much money. Well it puked out a plug; rt bank, 2nd from rear. Took the coil with it. Plugs were new @ 100K miles. ☹️ What's the proper fix, short of a new head? Bearing in mind current mileage, truck only worth about $3K running....
Thanks!
Ramnewbie
2002, 4.6L 150,000 miles. Was my old pos truck before getting the ram. I sold it to my daughter's bf for only $500. He's a full time student and doesn't have much money. Well it puked out a plug; rt bank, 2nd from rear. Took the coil with it. Plugs were new @ 100K miles. [emoji852]️ What's the proper fix, short of a new head? Bearing in mind current mileage, truck only worth about $3K running....
Thanks!
Find an actual "mechanic", he can helicoil that hole with head still installed. This was a common problem with the 5.4's and my theory was it was from over torquing the plugs on install.
Jeepwalker
WI
2012 Reg Cab, 4x4
Yep, good advice. They don't take that long to install and should last a long time.
K
KansasArt
Kansas
That's great that it can be fixed with the head still in place. Yep, going to a shop for this fix. Not gonna attempt it.
grizzstang
Calgary, Alberta Canada
DO NOT put a helicoil in the plug hole unless you intend to sell the truck. They don't last. I had a 2003 F150 before my Ram and the proper fix is a Timesert. Check any F150 site and you will see that. It also can be done without removing the head and will last the life of the engine.
K
KansasArt
Kansas
No helicoil here. Gonna use a timesert. Well, not by me... Plan on keeping it. Goes in today.
Ramnewbie
I had never heard of timeserts before. I just googled them and checked them out, they do look sooooo much better than a helicoil, especially for plug holes
GsRAM
2017 Dodge Ram 2500
Hemi, 6.4L
100% correct
Deki
Phx
Update on this? Did you get it sorted?
K
KansasArt
Kansas
Yep. Running great. $180, had to replace coil also.
