DBaker7777
- Nov 7, 2016
- 13
- 7
- 2016
- 5.7
I have a 2016 Ram 1500 I just had a 6 inch lift done. Recently noticed a squeak. When you push on it from the side the squeak seems to be coming from the rear driver's side Track bar. Should there be a rubber spacer because after examining it the passenger side is tight and has a rubber spacer in it but the driver's side just has the key that you can spin around and it is not so tight. First time I have had a lifted truck and this squeaking is annoying. Picture of where it is squeaking and red circle this spins around freely and is not tight. Not sure if it should spin around freely or not.
