When my wittle engine dies
TheMaddog
DFW
I'm thinking on throwing in a cummins in that *****. Not sure what valve to use, or what else to use.
Questions:
What gears?
Should I get new suspension for the front?
New trans? What to run?
And finally
Can I still use my 5 lug rims or do I have to convert that too?
Not feeling the hemi idea anymore
SmokedRam
Zephyrhills, Florida
Since you have a V6 truck...is there any difference in the frame from a V6 to V8 frame?
TheMaddog
TheMaddog
DFW
I don't think so, I have a **** ton of room in there.
TexasRammer
College Station, TX
Yup, at least stock ones. Im not sure what all you would have to do, but I would at least try and get some kind of beefier set up in there
TheMaddog
TheMaddog
DFW
I kinda wanna know the weight difference between the 2. The 5.9 and the 3.7
TexasRammer
College Station, TX
just searching google, the 5.9 is around 1020 lbs and a hemi is around 485. So the 3.7 is probably around 350???
TheMaddog
TheMaddog
DFW
Yeah, I'm gonna need some springs, and something else.
SmokedRam
I still say you're gonna have to reinforce your frame...I don't think any Ram 1/2 ton truck frame is fully boxed...and the 3/4-1 tons frames are...
At any rate, it would be something to look at...you dont wanna be twisting frames with all the TQ a cummins makes.
TheMaddog
TheMaddog
DFW
True. This place right beside our new warehouse does all of these. And the place next to them is a trans place.
the codes
Houston, Tx
Magnum 5.2
get some progressive spings from eibach :p bet they have something that will handle that kind of weight.
suzukiquadrider
cummins 5.9, 6.6 duramax
IT is easier and cheeper to buy an different truck with a cummins in it than to do a swap, we have tons of posts questioning swaps on here and most come up as it is a lot cheeper to buy a different truck.
TheMaddog
TheMaddog
DFW
I mean my truck only has 40k miles. Trucks that I find that have that much go for $30k, and I can look at the carfax. Other places don't show me that, but cheaper trucks
Muddinginamopar
Wilkes-Barre, PA
Uhhhhh....I didn't think the newer Ram's had front coils...? You may have to SAS it because the 2500 Cummins has a solid axle. But I could be mistaken.
TheMaddog
TheMaddog
DFW
well, i just know that they have coils... i'm thinking on upgrading everything, by the time everything is said and done, and i go into the poor house, my truck will look great...
