Is the 2019+ Media hub compatible with 2018 Ram
Caffeinator
California
Cummins
I've been searching and I've yet to find this question. I have a 2018 Ram 2500 with 8.4. I'd like to switch the media hub in the center console with the later model with USB-C ports.
The rear connectors look almost identical. I want to relocate my hub closer to the dash.
Here are the 2 media hub part numbers.
2018 68328704ad
2019 68397098AE
Thanks in advance
tron67j
Maryland
Perhaps one of the tagged threads a little down in this thread might help. Hopefully some who has tried responds. Good luck
C
Caffeinator
California
Cummins
tron67j, I've read and re-read that post a few times. The part 68328704A is what I currently have. It has 2 USB A ports and a 3.5mm audio input. The one from the 2019+ has 4 USB, 2 are A and 2 are C and the audio input. I was hoping the plugs in the back were the same but the new hub, 68272254AE, adds USB-C which should provide more power and faster transfer rates. Plus it is a lot cheaper. If I could find the pinout and schematic, I could trace to see if the upgrade would work.
